How do I do it?
This is how it looks on launch:
And this is how I'd like it to be:
Thanks!
How do I do it?
Thanks!
Expand it, then save the default lister. (Closing the window saves it by default, but if that has been turned off, use Settings > Set as Default Lister.)
Or, if you are using a layout, re-save the layout with it expanded.
The default lister, and layouts in general, will remember which top-level tree items were expanded when they were saved.
Thanks, that works great.
