The auto update box opens when there is a new beta, but the download never starts or makes progress.
This usually seems to be an issue with antivirus/firewall software blocking the transfer.
You can always download the same update via the web links in the updater. The installer that is downloaded is exactly the same file in both cases.
No problem... just wated to bring to your attention. Thanks.
