Hi everyone
I sometimes use the SIZE command (CTRL+L) to calculate folder and file sizes.
In addition I have to "manually" add the column in the lister. And it seems like extra work.
(I don't want the column to be in my listers permanently)
FEATURE REQUEST
If I use a keyboard shortcut like CTRL+L (in this example) it would be cool if the column SIZE automatically would appear in the lister.
Same for other similar operations.
Thanks
