Is it possible to have Dopus automatically scan all subfolders and cache the thumbnails so that the Thumbnails shows instantly when the folders are opened?
You can make following button:
Set FLATVIEW=On,MixedNoFolders
Set VIEW=Thumbnails
perhaps including something like
Set Sortby=modified
Set Sortreverse=on
in the "Set Flatview" section.
Thanks. I simply set it to Flat view based on the button idea and it started to scan.
Unfortunately, Dopus crashes after 20-30 min, sometimes with an error stating that there is not enough space (memory?) for the operation. I have plenty of space left in the cache (only 20% of max).
I think it tries to store the thumbnails for everything in the file display in memory, so if you're thumbnailing a huge number of files you can run out of memory.
It could also be a thumbnail plugin/extension crashing.
