Hi,
I need to free some space of my NAS and I'm searching for the best approach for selecting and deleting unwanted images.
I tried the SelectBase command when it was failing, I think that it's working well right now.
But I want to do it in a safe way.
I have JPGs files and the corresponding RAW files on the same directory.
I need to do a preview of the files and if some of they are not needed (i.e. the image is blurred) select them (JPG, RAW, whatever) and delete them.
I was thinking about making a button with a shortcut key association to let me do some actions over the current file.
My intention is (if possible) creating a customization on what files I want to see (i.e.: only JPG, RAW and some aditional extensions like XMP...) => Maybe any kind of Named filtering applied or Folder Format?
Customize the Dopus layout so files are viewable on one side and previewed on the other (with EXIF info)
Ideas I have in mind:
- To avoid losing files by mistake, create a folder named "Erased" on current folder and move there the "selected files" (all at once, jpg, raw,... of the same base name) and when I finish, delete the folder once revised or checked
- Selecting by "checkboxes" and convert to selection, then Delete (or move to "Erased" folder)
Any ideas of how to do it? Maybe there's a better and simple approach that I have not taken into account.
Please,
If you're on the same situation (maybe another kind of files, i.e: movies, compressed files, ...) I will appreciate some "light" here!
I will post my final approach when finished to the corresponding forum section!
Thank you in advance for your time,
Hini
