- /home\dopusrt.exe /restart
- Prefs LAYOUT="Your Layout Name Here" LAYOUTCLOSELISTERS=yes
Set LISTERSIZE=auto - Another alternative?
TIA
TIA
For what it's worth, #1 is my chosen method.
The 2nd one won't restart the process; it just closes the window and opens a new one.
But maybe that's all you want/need? What's the underlying aim?
I'm trying to understand what each does so I know how to choose one over the other in any particular circumstance. What does restarting the process accomplish that closing and reopening the window doesn't get you?
As I understand it:
reference: https://www.gpsoft.com.au/help/opus12/index.html#!Documents/DOpusRT_Reference.htm
2Chuck
Thanks for the info. I'll follow your lead and stick with /home\dopusrt.exe /restart
It "refreshes" DOpus and gets back to a default lister without any speed detriment.
Another difference is restarting the process will cancel any file copies (etc.) which are still going, while just closing and re-opening the window won't.
Which is best all depends on what you want to do and why.
