Beyond Compare v5 Beta not showing in context menu
Hi, I'm on dopus 12.33 x64 and am trialing 'Beyond Compare' v5 Beta (https://www.scootersoftware.com).
When using the default Windows 10 'File Explorer', I can see the "Compare" context menu item from Beyond Compare v5 Beta when right clicking on a file/folder. However nothing shows in the context menu of dopus. When using Beyond Compare v4 I could see it in dopus.
How do I fix this? Is there a way to enable it to show? Thanks.
From Beyond Compare 5.0 Beta - Known Issues:
  • Windows 10: Shell extension isn't enabled in non-Explorer apps.
So it seems like an issue on their side, not just affecting Opus.
There are also much nicer ways to use Beyond Compare in Opus:
Thanks so much for the reply. Hopefully BC5 will make its way into non-Explorer apps.
I've gone ahead with installing the "Smart" frontend for BC .osp and it works great with BC5.
Thank you again!
Windows: Fixed shell extension support for non-Explorer apps on Windows 10 and earlier.
