Blank (white) icons for folders and files within my Box directory (Dropbox equivalent)
Just as the topic name states. I've seen some other posts about this but with older versions of DO. Any help is much appreciated.
Is the same true in Explorer?
No, it only happens within DO.
Are you seeing this with 12.6?
Please try using ShellExView to disable any Box shell extensions, then reboot. Does the problem still happen then?
I am using 12.6 and "ShellExView" fixed the issue. Thank you so much, I really appreciate it. :slight_smile:
That probably means their shell extension was returning blank icons for some reason. Not sure why it would happen in Opus and not in Explorer, though.
