Since the last update (13.5), Box Drive won't automatically refresh file and folder listings if I have a OneDrive folder open (e.g. moved files don't show as being moved, renamed files don't show as being renamed, deleted files don't show as being deleted, etc.) until I manually refresh with F5. Once I close all of my OneDrive folders, Box updates as normal. Is this a known issue with a fix? Or should I just work around it until a patch comes out?
Please try Directory Opus 13.5.5 (Beta) and let us know if you still see a problem.
Thanks for letting me know. I've just installed the beta, and everything seems to be working again.
