Bug in "Convert Image..." when using EXIF rotation?
Hello,
trying to convert some images I came across following strange behaviour:
When calling the context menu item "Convert Image..." having selected many files and using the option Rotate (Use EXIF Information) at some point the image preview in the image conversion dialog stops showing the current picture and will continue showing always the same one.
I am attaching a screenshot of the image conversion dialog and some sample images.
If I don't use rotation or one of the fixed rotation options (90, 180 & 270) it works as expected. Problem occurs only with the "use EXIF Info" option.
Can anyone reproduce the error (select all sample images sorted by filename and call convert images)? Am I doing something wrong or is this a bug?
I am using the latest version of dopus (8224) on xpsp2
Thanks
Michael
bug.zip (373 KB)
