Thanks. I'm able to reproduce what you described, and I believe it's a bug in Everything.
To reproduce, so others can also confirm :
- The image must have an explicit label, meaning the
OpusMetaInformationstream exists. - In Everything's Advanced Options, opus_meta_information must be set to True.
When both conditions are met simultaneously, Everything fails to display the tags from the image.
My guess is that if the OpusMetaInformation stream exists and opus_meta_information is True, Everything will try to read the tags from there in all cases—even though that shouldn't apply to images (since tags are stored as metadata).
Please let me know if this makes sense to you.
