Are there any known conflicts with Nero and other burning software? My system will not burn multi-session CDs and I thought there might be a conflict caused by DOpus.
Opus doesn't have any CD burning functionality itself. Opus can call on Windows XP's CD burning feature, or run other programs such as the command-line version of Nero, to burn files to CD but it just launches the process rather than burning the files itself.
Given that, I don't think your Nero problem could be caused by Opus. It's more likely a problem with Nero and/or your CD writer.
Thanks for your response. I thought as much myself, but I wanted to eliminate DOpus from the possible causes.
Regards
