It's about the thing that appears when pressing alt + space.
Because I want it controled by the other program.
I use Win7 and the latest Dopus
thanks
thanks
I'm not sure what you mean.
Could you post a screenshot of it?
Which program and window is active when you push alt-space?
Which "other program" do you mean?
I might had to say 'System Menu', not 'Control Menu'.
And I think 'System Menu' is available on almost all ordinary GUI windows by pushing alt-space or by clicking 'application icon' that's on left-up corner on the window.
And 'other program' I say is so called 'menuHacker', Japanese old free software.
Opus merely adds three items to the menu. It does not take over the menu, so anything which changes it should still work (unless it excludes programs that add items to their menus, but that is fairly common).
The items Opus adds should be in the language Opus is set to use, not necessarily English, if that is the problem.
Thank you very much.
