i want to backup thousand of files to Blue Ray. But since windows can handle max 256 characters oriblem arises with hundreds or thousands of files. Can i use Opus for renaming path where filename+path exceeds 256 (or x) characters ? If so how
The is apparently an app “rename expert” that can do that but instead of yet another software application i wonder if Opus can do that?
Opus generally tries to stop you creating paths that long if they weren't already (because doing so will create problems with a lot of other things), but if the paths are already that long then it will let you copy/move/rename them (including to paths that are still that long).
thanks, but i already have thousands of files tha i want to backup but they have (some) too long names so i need to truncate not the filenames but the path.
It's certainly possible, you can do batch renames easily. We'd need to know an example of what the current names are and how you'd like to truncate them to know what to advise though.
there are thousands so examplifying names is not possible, so far it seems pathlengthchecker can at lease identify some thounds giving me an idea of commonaluties for renaming on folder level
