For some reason the image is never displayed in the Dialog -- there is just an empty background where the image is supposed to be. I know the path to the image is correct because when I use the same path to display an image for a Button control, it shows up as expected.
What am I doing wrong with the static image control?
Your image path seems relative (starting by "..\").
I don't know the exact context (path) you are when your script executes, but maybe an absolute path would be better.
Well, by golly, the absolute path works. I never thought of trying that, since relative paths seem to work just fine with Button controls. Is there a reason for the difference?
I would guess the execution context of a button is not the same as a script. If your current working directory is not the same, the relative path will lead to somewhere different.
The button and the static control are in the same dialog; can't imagine why the working directory would be different. But as long as it works...
Just to push it a bit further -- is there any reason why my animated gifs don't animate in a dialog? They display properly, but only as a static image.
