Can't manually input color?
Is this feature really gone?
I'm working to restore the config I lost when I upgraded, and I went in to set the source display color, but it seems there is no longer an option to enter an RGB value. Am I stuck with just a color picker??
See this post. It's in 10.0.0.1. Information is tucked away in the Beta Versions section of the Resource Centre.
Regards, AB
thanks aussieboykie
