Can't move with the right-click context menu
Directory Opus 13.19 Build 9399 x64
OS 10.0 (B:19045 P:2 T:1) SP 0.0
Hi. I have been using DOpus for 17 years. Up to today (maybe yesterday), I could right click on a file name to drag it elsewhere and I would be offered a copy or move decision upon releasing the mouse button. Today, right-click-and-drag does nothing. What's wrong? Thanks in advance.
Benoît Gauthier
Probably a context menu handler messing things up.
Have you tried to reboot?
Have you installed anything recently?
Usually, the culprit can be found using shellexview.
Other thing worth to read: Shell extensions which are blocked by default
Yes! A reboot fixed it. Thanks!
