Carbonite Virtual Drive
The virtual Carbonite drive no longer appears. I should appear under "This PC" as does the Google Drive.
Does it still appear in File Explorer?
In Opus, it's not under Cloud Storage instead is it?
It does appear in File Explorer
Cloud storage does not appear, even when selected in preferences
So it used to appear on the same machine but now doesn't?
Was Carbonite updated recently, or did the change coincide with an Opus update?
