is it possible to change the Viewer Pane position? I have vertical dual display and the Folder tree on the left, but I don't really need the tree to be that big, so I thought it would be nice to have the Viewer Pane under it. Is it possible? How?
The viewer can be on the right of the lister or on the bottom, but can't currently be placed under the tree. (Well, it can be under the tree, but it will span the full width of the window, not just the tree part.)
