I found that my native language Norwegian was ready in Dopus and changes language. But it seems like there is used some kind of translator, cause even codes in the status bar got translated. That broke the codes and even the default ones. Are there any "libraries" with default, og better status codes?
The Preferences windows has a menu with several status bar presets.
If those don't do it for you, check out the thread pinned to the top of the Buttons & Toolbars forum for more.
[quote="leo"]The Preferences windows has a menu with several status bar presets.
If those don't do it for you, check out the thread pinned to the top of the Buttons & Toolbars forum for more.[/quote]
The presets got translated aswell, even inside the brackets, and that didn't go to well.... I'll look up those threads
Opus must still be set to the other language if the presets aren't in your language of choice.
This is a matter of improperly translated status bar codes.
It should be reported to translator.
Here is how it looks like for Polish.
Yes, you should report it to Fred Bloggs (Swahili Oversettelse) ![]()
I could easily use english (default) codes here as that has been my Opus language for ages (since the Amiga days)
I just had to try it out in my native language when it got available, but really, its kinda unfamiliar to se things in Norwegian and not in english as I'm used to. It's more than likely I'll change back to english to better understand what I'm doing again ![]()
[attachment=0]Norsk.png[/attachment][/quote]
You're right. I'll see if I can find his mail adresss and tell him.
Hi,
Unfortunately our last Norwegian translator was unable to continue to help with the translations. If you are able to help us with updating the translations could you drop me an email to my normal email address please.
