Changing backgrounds
I want to change the default dark background to Dark Green. When I click on it and press OK, nothing happens. Any ideas?
Are you changing Preferences / Colors and Fonts / Directory Opus Colors / File display background, or something else?
I am trying to change the file display from the current 'Dark Black' to 'Dark Green'.
Which color are you changing?
When I say 'Dark Green', I mean a Lister.
The color I mentioned above is the one for that.
Any suggestions?
Leo already explained that to change the lister background color you need to change the Preferences / Colors and Fonts / Opus Directory Colors / File display background.
If this is not what you mean, it's better to take a screenshot of what you mean and post it here.
If changing the above setting doesn't seem to do anything, it may be because it's being overridden by a per-folder color on the Preferences / Folders / Folder Images page.
I went to Preferences etc and then came to this page. I then clicked on Display I wanted and clicked OK but nothing changed.
There’s a problem with that particular theme:
