My default layout is a vertical dual pane. When I unclick the dual layout button and go back to a single everything is fine but when I click the dual vertical button again it doesn' t go back to the same layout.
I had to open my operations toolbar using code behind the button but that then makes the button specific to this layout. Maybe there's a better method of returning back to the dual pane that's preferred?
The other problem is that it loses my preset tabs on the right-side panel. I'm not sure how to get them back other than re-opening my default layout because tabs are not kept like toolbars.
