Hello,
when I start Directory Opus from an USB drive changing folders can take seconds. Sometimes it works normally but then after a while it's getting really slow. Sometimes it happens right from the start.
Regards
Martin
Hello,
Regards
Martin
Does using the "dongle" option when exporting Opus to USB, and then copying the program to a local drive when running it, help?
No this doesn't help. But what I just realized is that when I use the Windows Explorer the browsing between folders is fast, but when I right click inside the folder it takes seconds to open the menu. Could this be related to the problem I'm experiencing?
Yes, that sounds like a shell extension is going wrong, or something else that can slow things down randomly like having a network drive mapped to an unreachable computer.
These two guides have suggestions:
Crash, exit or high CPU usage when viewing certain directories
Crash, exit or high CPU usage when right-clicking certain files
I have disabled the extensions and now I don't experience the waits anymore. Shift-right-click for opening the menu with all entries works fine for me as a workaround.
