Changing how DO handles special characters rename ("&" , "/")
Hello. Here is situation:
I batch rename files sometimes to include "&" . How do make DO accept it and not completely duplicating the new name string, which is default.
Also, if I paste the new name which might contain "/" like from dates, can DO simply ignore the / character or do something else? The default seems to be making new subfolders in the original. Same situation with pasting a new filename containing colon ":" which defaults to creating new location. I seem to remember previous version would simply ignore that colon character, now it's different.
Thanks.
Please link your account.
I don't think there is anything special about the & character when renaming.
What are you doing exactly?
In standard wildcard mode and Opus 12.20.4, colon characters are ignored when pasting, unless they are in a valid position to be part of a path (i.e. the 2nd character in the name) or part of a script column name (after {scp).
Slashes are allowed since you may want to create sub-directories when renaming.
Thanks, Leo! I inadvertently had the rename set to "regular Expressions" and Old name to (.*)\.(.*) , thus my difficulty. Really appreciate the quick reply and help!
(Also, linked account)
