Hello there,
as mentioned above.
Can you help me figure out how to change the color of the context menu for files and folders?
I looked up the help menu but wasn't able to find a solution...
Thanks!
Hello there,
as mentioned above.
Thanks!
Preferences / Display / Colors and Fonts / Toolbar and menu defaults can change most context menus.
Doesn't affect a couple that are handled by Windows instead of Opus. (Right-clicking on a drive is one example, from memory.)
