Invalid date
My forum name is Levers. I have a full lifetime licence of Directory Opus
Pro (from now on DO). Its version number is the latest as of 160723. My win 10 is 22H2 build 19045.3208 with all updates) based on a mobo of ASUS Rampage V Edition 10, 64 gigs of ram and 2 EVGA 1080i's in SLI.... all water cooled except the ram.
Bear with me.....
During this year, I have experienced a fault in win 10, which I thought was one of the winups. How it occurs is that slowly, font single letters start disappearing in my browser URL....so I tested this with many including my favourite Librewolf, Ungoogled chrome, and edge (the latest version of Edge 114.1823.82)...the issue the same, and it gets worse the longer I leave it (more letters disappear the longer I use it). It also effects Kaspersky Total Security (KTS) fonts when I open it (from the task bar) until there are no fonts left. The only workaround I found was to reload the browsers and close KTS totally and open it again, but eventually, this becomes a pain in the backside. Eventually it does the same thing. Additionally, when I go to the fonts option in control panel, I was unable to execute it...
Many searches in Google/DDG/Qwant etc gave me no joy, so......
After 3 months of this, I had had enough so last week I started to reload the pc, using Acronis as my imaging software, backing up along the way. Cutting a long story short, I got to a point without DO, then loaded DO again and looked for the issue and there it was.
I removed all of DO using M$ uninstaller in control panel. I was fully expecting it to rear its ugly head, but simply it went away with DOs removal. So I tried it again to test my hypothesis...loaded it with all the options and bang, there was the issue again. Removed it and rebooted and the issue disappeared.
I am convinced there is an issue with DO... somewhere! Or maybe a clash of software
Well, that is about it! Over to you guys. Looking forward to your kind response.
Best
Levers
