Check-box color
Is it possible to change the check-box color. Thanks.
Which check-box do you mean?
Sorry, I,m viewing in list mode with check-box mode switched on. The small square white box in front of each folder which you can check or not. Thanks.
I think those are always drawn using the Windows Visual Style (which you can only really change these days using something like Stardock's Window Blinds).
Something we could make configurable in the future, though.
No big deal, I'm sure I can manage with white squares, plus it's quite rewarding finding something that DO can't do. I haven't found the button for making tea yet, maybe you could put that on your to-do list as well. Thanks.
