If I have C: selected and have C: expanded, if I click on the D: drive icon in the toolbar, I end up with D: selected in the folder tree at the very bottom of the folder tree.
I'd like to have it moved to the very top of the folder tree when I click on the drive.
Christiaan - I tried the two preference settings, and it works better.
However, I can select a drive and have it highlighted, and have it 1/2 way down instead of at the top.
For the 'Go' commands, are you suggesting that I somehow map these commands to the drive buttons (not sure how), or create new buttons to perform these actions?
What I'm really after is to have it function like the 'start folder tree at current drive' - but still be able to get to the desktop, etc. at times.
Possibly I should create 2 'Style's, one that only displayed the folders for the current drive, and one that displayed the full tree structure of the computer.
BTW - I've never used 'go' commands. Is there a command window to test them?
Just select 'start folder tree at current drive' to only show the current drive being used and click Go > desktop to get to the desktop or create a button on your toolbar with the function: Go /desktop or Go /mycomputer
BTW: You have to create new buttons for the GO commands, you can't edit the drive buttons.
To test commands, just add a Command Field (a text entry field) to a Toolbar and enter a command string.
