I create item in file and folder context menu with this command :
@keydown:none
clipboard copy nofromfocus
@keydown:shift
Clipboard COPYNAMES=unc
if i shift clic on file in network location, it's ok, but if file is on hard drive, name with extension is sent to clipboard.
Normal ?
Not that if i create item with only "Clipboard COPYNAMES=unc", it's ok on network and drive.
