Hello again,
want to copy to the clipboard
FileName without extension: Clipboard COPYNAMES=nopaths REGEXP "([^.]*)(.*)" "\1"
FileFullName: Clipboard COPYNAMES
with delimiter "=" between both parts (like keys/properties in INI-files). How can I to achieve that?
Many thanks and greetings
opusfreak
Leo
#2
So you want to replace the last dot in each filename with an equals sign?
Hello Leo,
like
FileName_without_extension=FileFullName
e. g.
File=C:\MyPath\MyFolder\File.ext
opusfreak
Leo
#4
This should do that, as long as all files have extensions, and you always want just the last extension (e.g. .rar
instead of .part01.rar
Clipboard COPYNAMES REGEXP "^(.+\\)([^\\]+)(\.[^.\\]+)$" "\2=\1\2\3"
Keep in mind that =
is a valid character in filenames, so your output format will be ambiguous sometimes.
