Clipboard paste to text file (native CTRL+V on lister) used to produce a UTF-8 no-BOM encoded file, up to v 12.9.4.
Latest version (12.10) is producing a UCS-2 BOM encoded file.
Is there any way to switch back to the previous behavior, or make it so it's configurable?
I don't think that changed between 12.9.4 and 12.10.
I just checked with 12.9.4 and pasting text that cannot be represented in the current codepage creates a UTF-16/USC-2 file in that version as well. I think it has always worked that way, or at least has for a long time.
Are you sure you're testing with the same kind of text that you were using before?
Actually, you're right; I just rolled back to 12.9.4 and it behaves the same way.
There doesn't seem to be anything different with the text in particular, though; saving it directly from Chrome produces a UTF-8 no-BOM encoded file.
Any chance you can make the encoding configurable? Or any way of "hacking" it so a specific encoding is forced?
That probably makes sense. Or just switching to UTF-8 since it's much more common.
You could have the Ctrl-V hotkey run a script that checks what's in the clipboard and, if it's text, converts it to UTF-8 and writes the file itself, and otherwise runs the normal Clipboard PASTE command.
Or something which is run after pasting the data to convert the file from UTF-16 to UTF-8. (A script could do that as well.)
(Opus provides an object for converting text between encodings which could be used by both types of script.)
The current behavior depends on the type of text on the clipboard. If there is Unicode text on the clipboard it'll be pasted as UTF-16 (with a BOM), otherwise it'll be pasted as ANSI.
In the next version we'll add the ability to specify the desired encoding.
