Hi There,
Are there plugins that will allow us to view code in the view pane with syntax highlighting? Specifically I'm interested in AutoHotkey v1 and/or v2.
I'm not referring to Opus' scripting abilities... I mean just viewing .ahk files in the Viewer Pane.
Another option is the Monaco plugin that comes with PowerToys (also works in File Explorer's viewer), but the last few times I tried that it was so bad (long delays, not showing anything at all for some simple files) I made Opus block it by default. Maybe it's better now though.
