Color for background and font of utility panels?
Hi there,
Using Opus 12.10, and happy with the additional options to really make a dark theme possible. However, I am unable to find a way to change the background and font colors of the utility panel. Is that possible at all? If not, please make it so!
Thanks,
Anakha
Not possible yet, unless you change your Windows theme using something like Window Blinds.
Ok thanks for your quick reply, Leo. I'll just have to live with it a bit longer :stuck_out_tongue_winking_eye:
Is this possible yet? I came to the forum with this same question. I'm using a dark mode theme in dopus but the utility panel is blaring white.
Was this ever implemented or can we put in an enhancement request?
Thanks!
No change yet. We're looking into it but it's quite complicated, and the dark mode APIs in Windows 10 are both undocumented and completely unfinished, only really doing the bare minimum Microsoft needed for their own software.
Would definitely go down well. I've created such a pretty dark theme that I find myself avoiding the utility panel features out of sympathy for my eyeballs.
