In a lister file pane the sorted column is always white regardless of the color chosen for "file background". Is there a way to change the color of sorted column? Thank you.
Yes, see Change the color of the Name (or sorted) column in the FAQs.
Thank you sir. I did check the FAQ first but simply missed that.
