I am visually impaired so use a dark theme downloaded from the forum (thank you to the creators). Am using the 30-day trial on Win11Pro
Found out that when I have folders with many files open and I try to select a single sub-folder or many to move or copy or compress to zip/rar --- I can not see what I have selected.
Ok, should be no problem, I open Settings, Display, Color and Fonts -- or so I thought, as I can not figure out how to change the darkness (blue shade on black) to something that would make it stand out.
Here is what I mean. 6 folders selected on the right side panel.
Make sure Preferences / Display / Options / Visual styles override file selection colors is turned off when using dark colors, since the visual styles which are part of Windows are designed for light colors.
