Colored Label Headers
Hi there,
is it somehow possible to have colored label headers?
as you can see in the screenshot all the headers are orange. it would be nice to have green header for green label, red header for red label ....
and if possible would be cool to have also colored folder icons based on the label color.
thanks,
Manu
On the labels page in prefs there's an option to also color the icon and text for your color labels
I don't think that's possible.
You could change the icon color like this:
for folders and text it works. thanks guys.
for label headers @Leo maybe this is something that can be implemented in an future update? :slight_smile:
It looks like what you're talking about the grouping headers.
The names here can really be anything since it depends on the column you're grouping by: size, attributes, labels, extensions, some schemes on the name, any new computed custom column you'd be able to define ...
Even the type is random: can be strings, can be integer values, can be ranges (if you group by size).
So having this customizable is going to be quite hard to even come with a way to present the customization.
The only way I can see would be to limit this customization to labels where there would be a new propery (something like group header color) for each label which would then be applied only when Grouping on the label column.
