Is it possible to rename columns in DO? I'd like to shorten some of them to allow for more to be displayed, which would be my preference for doing so over other possible methods.
It depends which column you mean. If it comes from a script then you can rename it.
I can't find such a script, which probably means one hasn't been written.
I'd like to rename columns such as Aspect Ratio to Aspect (or A.R.) and Subtitle Tracks to Subtitles (or Subs), etc.
Aren't those columns from the Icaros script you're using?
Some of them, yes.
The ones from the script you can rename by editing the script.
Of course. That's just occurred to me as well. Thanks.
