Column value missmatch with Explorer
Hi,
as shown in the image, in Directory Opus, all files are listed as "available on this device", contrary to what File Explorer display.
My goal is to perform a search in DO for all "sync pending" files.
Any idea on how can I achieve this?
Thanks
In Preferences, try turning on Display extended sync attributes for cloud folders. Where it is differs by version:
Opus 12: Folders / Folder Behavior
Opus 13: File Display Columns / Options
It can also depend on the Windows versions, as Microsoft are constantly changing/breaking the API for this, depending on which process asks, or exactly how it asks.
I'd also expect Synology's software to be able to show a list of what's synching, similar to what OneDrive does via its tray icon, but haven't used it myself.
