I had this issue before but found the solution. Now that I had to re-install windows, I have the same issue, this time I can't find the solution. Really, it should not have to be this hard (and common). I find the 'Name' column is pushing the other columns off the edge. I REALLY don't need to see the whole name to recognize my file. How do I change the way the column widths are handled?
