For images Opus offers columns with W and H (pixels).
I would like to filter and delete images below a certain total pixels size.
I can not simply sort on "W" (width pixels) and then delete below a certain width : many images are photos shot as 'portrait' , so they have a smaller width, but the height is okay and v.v. I can not delete photos below a certain height in pixels.
In that case I assume the total number of pixels (i.e. W-pixels x H-pixels) should then be considered.
Have not found any viewer so far offering a kind of 'Total Pixels' column.
With 'Total Pixels' I meant: pixels W multiplied with pixels L.
AFAIK this column does not exist and neither does it in the number of image viewers I checked.
Something like:
This is probably the only way to delete small sized images (small on screen)
Many thanks indeed! This is exactly what I have been looking for.
From various image sources on Internet I have downloaded many, I mean many, images from my hometown in the old days. A lot of them are simply too small and are useless.
In my case and on my monitor, the threshold is somewhere around 280-300.000 on 'Total pixels'. All below that, I can simply delete.
At first I gave 'Dimensions' a try, but discovered that the sorting is somewhat different from total pixels.
Anyway, again, many thanks!
This definitely saves me a lot hassle.
