This script adds some XML and XPath columns.
The custom columns can be configured to target files or folders reading a specific file within the folder.
There are three columns that do not require configuration (only relevant when targeting files not folders), and there are more generic XPath columns.
The columns:
- Is valid XML: Is the file valid XML (true/false)
- Root Node: The name of the root node
- Root Node Namespace: The Namespace of the root node.
- XPath: These columns will return the text value of the first select node using the provided XPath expression.
This button displays the above dialog.
<?xml version="1.0"?>
<label>Xml</label>
<icon1>#XmlColumns:XmlBlue</icon1>
<function type="normal">
<instruction>XmlColumnsConfigure</instruction>
</function>
</button>
XmlColumns.osp v0.4 (14.5 KB)
If you would like to test, try this xml and then:
- XPath
.//*[1]will match the amount - XPath
.//*[2]will match the date
<?xml version="1.0" encoding="UTF-8"?>
<note>
<amount>50</amount>
<date>2017-12-13</date>
</note>
feedback welcome.
