Command Reference - Dialog with Yes/No
Hi,
I create a button to delete all the metadata of the selected files, but I want to show a confirmation dialog with Yes/No button and then delete the metadata if the user select "Yes". Is there a way to do it, or I will have to create a dialog with "Yes" and "No" in a list and then select "OK" (hopefully no!).
You can use @confirm to do that.
Thanks! Exactly what I want.
