Note that the randomfile list is already available. A simple .txt file with many random names.
As said, right now I open that list and clipboard copy a part of the list, which I hope will be sufficient, and then use RenameFromClipboard.
My idea was to use data from a list, instead of from clipboard, so the 'steps' of opening/clipboard copy would not be necessary anymore.
Just an idea though.
I just discovered there is something similar to what I suggested: 'From file rename script version 3.1' (from gieron).
Gave it a try.
Drawbacks (for me, that is):
-the 'source' filelist with random names should always be placed in the folder with the files to be renamed first
(so it requires me to first find the file with random names and then copy it to the respective folder - i.e. browsing thru folders,
click, click.. it would be better to have the file list in the Opus directory by default)
-it does not support files that are displayed when using Set FLATVIEW=Toggle,MixedNoFolders
Sounds like a very specific and (odd? o) usecase but why not. It's not related to renaming things, so something like this won't make it into this addin or its followup (which I need to upload someday). Cannot remember your scripting capabilities, but modifying this one to do what you imagine shouldn't be too hard.
Indeed, very specific, long story and not really interesting for others.
Just now found a workaround though, 3rd party software.
So forget it.
btw: my scripting capabilities are nil...
Just a very minor tip tbone, the latest is 0.3, on the 1st page 0.2.2 is said to be the latest. The one listed above 'latest' is actually indeed the latest, i.e. v0.3.
My button doesn't work anymore
When I use the button it tries to remove the file name and only leave the ".{ext}" and stops after the first file because it's trying to make a file with the same name.
You can avoid that problem by using %item.new_name% instead, and adding IGNOREEXT to tell Opus to preserve the file extension instead of the script having to do it:
(The old FILEINFO switch was also removed as it isn't needed in Opus 12 or above.)
Thank you
It's good to know that is built in as well.. I have avoided using the built in rename thing in the past because Bulk Rename Utility usually does what I want and I don't know how to script.
@Twilight
Please go with Leos suggestions or add actual file extensions to your file names in the clipboard, I think that's the cause of the problem. Not saying that there isn't something to be fixed here. o)
I'm not 100% sure now that that was the same button.. My C drive died recently and I stupidly had the configuration backup on the same drive. If that command does only work if the extensions are there that could make sense. Currently I'm copying folder names and putting them on files.. It's possible I only used that button when I was copying names from one set of files to another before. So there might not be anything to fix but I don't know.
I do think it was the same button though because I think it came with the theme (or whatever it's called) I'm using.
Yep, I obviously missed that, but to my defense, I updated and wrote the correct version at 3 other locations at least! o) Now updated inner-script as well, thank you! o)
Is anyone having trouble with this script? It doesn't work for me anymore. When I select a batch of files and run RenameFromClipboard, it opens the rename window with only the first of the selected files and doesn't bring the clipboard names in.
