Command to toggle system files visibility
I'd like to be able to toggle visibility of system files with a button on the toolbar. Does someone know if there is a command and syntax for this?
would I need two buttons, one for ignoring system files and another to make them visible again?
thanks for any help you can give...
Rod.
One button can do it.
Set HIDEFILTERATTR=S
Or, if you want to toggle the option in Preferences (which hides files if and only if they have the System and Hidden attributes set):
Set HIDESYSTEMFILES=Toggle
