Context menu for "Drive"
I added a context menu entry to File Type "Drive" :
Standard Function: Go FROMSEL NEW
and called it "Open in new lister".
But this item does not show when I right-click a drive in "My Computer".
What am I missing ?
Thx.
Drives show the standard Windows context menus, unlike normal files and folders which show Opus's custom menus.
It will work if you add the menu item in a way that File Explorer would understand:
"C:\Program Files\GPSoftware\Directory Opus\dopusrt.exe" /cmd Go "%1" NEW
That means it works in both Opus and other places, too.
Thank you.
OK, I am done testing DOpus.
I'm speechless.
If I buy a single Pro license, can I use it in VMs on my computer ?
That's fine as long as the VMs are not used by multiple people at once or anything like that:
That works. Just placed my order 10mn ago.
I can't believe I went through all the utter c**p since Windows Vista for so many years without DOpus by my side. I'm at peace now.
If you turn your attention to Unix/Linux someday, please do let me know.
(if so, don't talk to the open source guys, just do it. They are way past the Orion nebula and will never make it back to earth in our life time)
