Hi there,
I'd like to have custom colors and context menu for specific filenames:
i.e. myfile.tst instead of having it for all .tst files.
The filetype editor only allows this for extensions.
Maybe the solution is obvious but I can't find it...
Anyone a tip?
I was wondering if a VBScript at DOpus startup would be the solution...
I can't believe this is something that cannot be achieved with that fantastic piece of software
Steve
December 17, 2008, 9:46pm
3
I don't think there's anything within Opus to provide for this filename based colouring, therefore a vbscript at startup would have nothing it can do.
You could try filing a request with GPSoftware.
Thank you Steve for your response.
I'll try filing a request then. Tx.
Stephane
