When I right click on a file I see context menus such as "7-zip", "Select file to compare", and "EditPlus".
(These of course are there as a result of installing 7-zip, BeyondCompare, and EditPlus).
I see those context menus in File Explorer as well as in Dopus.
Several other context menus, such as "Convert to Adobe PDF", "Combine files in Acrobat" (both due to the installed Acrobat), "IDrive", and "Create Smart Backup" (due to IDrive and EaseUS Todo Backup respectively) appear in File Explorer but do not appear in DOpus. I would like these context menus to appear in DOpus as well. Can anyone offer some advice on how to make that work?
I have already checked to make sure that "Hide Windows Items in context menus" was unchecked (in preferences).
I read the 3 sections I found in the help file by looking for "Context Menus" in the index, but even after that I'm not sure what to do.
Thanks
~Paul
