Hello, I am using this Coodesker application however the double click on desktop does not work with this app enabled.
I also asked the same request in their forum.
If it takes over the desktop by replacing its window, then our desktop double-click hook won’t know the new window is the desktop and will ignore it.
If they have their own double-click mechanism, it should be possible to make that open Opus instead.
