Copy command unavailable while using wildcard
When filtering files in a lister, like example, my copy/move commands won´t work from the hit list. It would be an enhancement, if actions on that file would be possible right from there.
Works here just fine.
What are the command you use and which version of Opus?
[quote="xbprm"]Works here just fine.
What are the command you use and which version of Opus?[/quote]
I´m using the new OI version, but i forgot to mention, drag & drop of course works fine, i referred to keyboard actions only.
So only when i use the keyboard commands, nothing happens.
I use the newest OI version, too. And my keyboard commands just work fine. No buttons.
I tried the commands while the command field was still open, this was obviously an error. :blush:
But i just found out, that after the search is finished, pushing Enter key is necessary before trying to copy. Thanks a lot!
:sunglasses:
[quote="abr"]I tried the commands while the command field was still open, this was obviously an error. :blush:
:sunglasses:[/quote]
That's logical. As long as the FAYT field is open the keyboard inputs are directed to that field.
Well, it´s sort of logical, but on the other hand using keys like ctrl, shift etc. could have overridden normal chars. But anyway, now i now how to "fixate" the filtered items.
