I have a copy filter where I want to copy all of the files with a particular file name extension (no problem there) but also where they contain either one of two text strings that need to be entered as a regular expression.
It can be seen in the attached screen shots.
I have also attached a file that meets the criteria of the search, yet it does not get copied.
Interestingly, if I change the order of the "Contains" clauses, it does work. I guess the first regular expression is somehow important?
V V strange.
Regards
Dave A
ScreenShot.zip (36.2 KB)
